I would not be too hasty in dismissing XP as the problem. XP wants total control of everything. Even after booting up to your normal desktop screen, there are things still going on in the background for a few seconds (which may explain the 11 times). Now this could be a print driver or it could be XP trying to reset the parallel port or a combination of both. I've had troubles using the serial port with XP because it does things differently. Things to try: Go to BIOS setup and make the parallel port standard (not EPP, not ECP). Remove any print drivers that exist. Last resort, replace XP with Win98, then try Win2K.
