store time channel
Dear all!
I'm using the following vi to store the info coming from a physical channel in a tdms file. How can i do to store the time info as another channel in the same tdms file?
Thank you very much in advance,
Miren
(3,176 Views)
The time information is stored in the waveform channel as a component of the waveform data type. Anyway, I have mad a little change to your code so you can get a timestamp for each sample you receive from your card.
(3,135 Views)
Thank you very much for your answer. It was very helpful!
(3,132 Views)
Mark the solution as accepted if it solved your problem Smiley Happy
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(3,117 Views)
