05-03-2012 12:14 AM
Hi everybody..
I want stop the most inner case structure after executing only once but the count is keep on increasing i cannot use STOP...please help
Thanks in advavce
05-03-2012 01:02 AM
The case structure is kept inside the for loop and that will get executed depending on the value you enter in the N Value of both the for loops. You can maintain a shift register to restrict the case for single execution.
05-03-2012 01:08 AM
Sorry Sir but can explain in detail....
Thanking you...
05-03-2012 03:08 AM
I have attached the vi containing a shift register just check how it is implemented and make it in your logic depending on your preference.
05-03-2012 05:15 AM
thank you sir...
05-03-2012 07:02 AM
Hi Everybody
In this VI when Boolean UDA is connected to single case structure is working fine but when it is connected to a another case structure it is showing abnormal result.
I am attaching both the VI. Any suggestion will be helpful
