01-15-2015 05:41 AM
I have a problem when I want to display a .bmp image. I use the functions "Read BMP File.vi" and "Draw Flattened Pixmap.vi", but unfortunately an error occurs:
Error 16 ocurred at read BMP Header Info.vi
Possible reason(s):
LabVIEW: Image not found.
NI-488: SRQ stuck in ON position.
I don't know why it happens. I have checked the folder where the image is stored and the image exists and all is correct. I have also checked the path of the image and the path of the "Read BMP File.vi" and are the same.
I have attached this vi. Its functionality is to take a capture of the oscilloscope, so store it with a name and the display it in the front panel of the vi. If you open the file, you will see that I have used the flat sequence. I have used this structure because I thought that LabVIEW didn't find the image due to time issues ( the program tries to display the image when it hasn't been created yet).
I have been looking for information about this error, but I haven't found anything and I don't know what I have to do.
Any help is appreciated.
01-15-2015 05:48 AM
06-28-2016 09:05 AM
Luisi,
Were you ever able to find a solution to your problem? I believe I have the same issue, can you give some insight? Read below:
I am still struggling to figure out what is special about the saved image from the TPS2024.
As mentioned in a previous email:
06-28-2016 09:28 AM
Hi grscheben,
it would help a lot if you would attach the BMP which refuses to open in LabVIEW! (Put it in aZIP archive!)
And it would help to compare the original BMP with the re-saved one with a HEX editor type program to spot the differences…
06-28-2016 09:43 AM
GerdW,
Per request here is the problematic "scopetest.bmp" in a zip file.
George.
06-28-2016 11:26 AM
Hi grscheben,
two notes:
- when (re)saving your BMP as "ordinary" BMP it's filesize changes quite a lot. You should have noticed this already!
- when debugging the LoadBMP function with standard LabVIEW tools (like open subVIs and look at their FP) you should have noted the function "Read BMP header info": it signals a "compressed bitmap", which is the reason for loading failure within LabVIEW.
Conclusions:
- BMP file format is mostly obsolete.
- LabVIEW doesn't support compressed BMP files.
06-28-2016 02:05 PM
GerdW,
responses to your statements:
"when (re)saving your BMP as "ordinary" BMP it's filesize changes quite a lot. You should have noticed this already!"--> I did. I TOLD YOU about this observation.
"...should have noted the function "Read BMP header info": it signals a "compressed bitmap"--> I don't seem to have "Read BMP header info" on any of my pallete's. is that funtion part of a labview add-on tool-kit?
"- BMP file format is mostly obsolete. - LabVIEW doesn't support compressed BMP files." --> Unfortunate. Bitmaps are the preferred export method from the Tektronix equipment supplier to read image data over the Serial interface. The file format I sent you is the only supported BMP format supported by Tektronix.
ADVICE: The spirit of a technical forums are to provide a venue for users to support other users. They are not intended as a venue to vent or otherwise "Troll". If that's is your intent GerdW, there are other forums that would be better use of your time.
06-28-2016 02:34 PM - edited 06-28-2016 02:37 PM
Hi grscheben,
The mentioned VI is a subVI of the ReadBMP function.
I told you to look at subVIs.
ADVICE: Do listen to what people tell you!
My fault, I didn't notice this part of your message…
But LabVIEW supports other file formats as PNG.
And there are a lot of free tools to convert image filetypes into each other. You could employ such a tool to convert those Tektronix BMPs to plain PNG files. It's just one SystemExec call away…
(A serious question: How old is this Tektronix device? I hope Tektronix does support other/better image file formats nowadays.)
No, it isn't my intent to troll.
It's my intention to make people think about their VIs. Most often that's all they need… 😄
