split 1D array of string with spaces into solitary segments
Hello ppl,
I wanted to post it because it took me a while to do this thing. I have array with spaces and I make 2D array. For instance:
?NM 100.0 ok ->
?NM
100.0
ok
Take a look. maybe somebody will find it helpful.
Message 1 of 13
(5,084 Views)
Why not just use the Spreadsheet String to Array function? You can use a space as a delimiter.
Message 2 of 13
(5,078 Views)
Nor do you have am array with spaces or are you creating a 2D array.
Message 3 of 13
(5,077 Views)
can you please give me an example?
thanks
Message 4 of 13
(5,074 Views)
that's what I have in the exit of the device. I need to check if there is ok there and the wavelength number...
Message 5 of 13
(5,070 Views)
all is lack  here is after your string should be Trim white space.vi and then it works good. 🙂
Message 6 of 13
(5,066 Views)
There is a primitive for empty string and your array building can be replace by an autoindexing tunnel at the loop boundary.
Also, your code does NOT make a 2D array but a 1D array. What do you actually want to achieve?
Message 7 of 13
(5,065 Views)
nothing to achieve only to share my solution.. because I searched in internet and found nothing.
Message 8 of 13
(5,058 Views)
I don't understand your comments. Please explain how your code relates to a string array input and a 2D output. And why you think it is better than the LabVIEW primitive function I mentioned.
Message 9 of 13
(5,053 Views)
if you want to remove it.. remove it.. I didnt find that option here... just I've searched through the internet and didn't find nothing to answer my needs. I didnt know about that primitive function that you've mentioned.. now I'll know.... sorry for bothering with my "good will".
Message 10 of 13
(5,041 Views)
