Salutations,
You'll have to excuse me, it's national bring your child to work day and I wasn't able to procreate before this instant in time, so I'm a bit slow today with all the child chaos that's taking place.
So, you want to import the data from an excel file, search through it and find a window of 10 to 20 nanometers, and then polynomial fit this, then apply a differential to it?
If that's what you so desire, you can do that without a problem. Importing an .xls file is sort of a pain (As far as i know) so i always save them as .csv files. This will eliminate multiple page files in excel, and some formating may be lost. However, it will now be a comma seperated file.
However, now we can open it in labview, go to "File I/o" --> "Read from spreadsheet file.vi" Select the file location and set a constant for the deliminator to be a "," that way it'll handle our comma seperated file. Assuming these are all numbers, if they're not, you'll have to do some other tweaking (ie, if you're trying to import dates etc... it will be a bit trickier).
Now that we've got our array, you could bin the data for the 10-20 nm range, by incrimenting through a for loop and checking those upper and lower bands... use a case structure and an "and" boolean and bin the data if they're both true, or disregard it. Now this isn't the fastest technique (depending if you data is already arranged etc...), however it will work.
Now, to polynomial fit the data do "Analyze" --> "Mathematics" --> "Curve Fitting" then choose the one you desire.
To Differentiate that you may need to rebuild the data set, depending on how you chose to curve fit, but the differntial operator is located at
"Analyze" --> "Mathematics" --> "Calculus" -->"Differential.vi".... Note: Differentiating increases the amount of noise in a signal.
Note: The curve fitting and the differential tool may not be in the base package. If they aren't, well, there are numerical techniques for both. You could write your own Vi's. Maybe not as fancy as labview's, but you'll survive i'm sure.
Hopefully this provides you solid footing for advancing.
Sincerely,
ElSmitho
