04-08-2016 03:10 AM
I am trying to implement the Limit Testing VI, using the Limit Specification VIs to define the upper and lower limits, into a waveform graph.The Limit Specification VIs don't accept a timestamp from the waveform t0 directly, and will only accept this parameter if converted to a DBL as per one of the NI examples, i.e. the Limit Testing Measurement one. However this only seems to work in the example because it is a zero timestamp. When I try it with an actual timestamp, I get error -20337 'specified timestamp occurs after the end of the limit'. How can I resolve this?
04-11-2016 06:46 AM
Hi DLTD
Using an actual timestamp will give you a value for x0 of 9.354E+9. To avoid the error, the limits in the limit cluster have to be two arrays where the x0s are in range of 9.354e+9. I am not sure how you create them, as this part of the program is missing in the screenshot, but what I can see, is that you are giving scalars instead of arrays as limits.
On the other hand, I just tried it with good input values for a real timestamp. I didn't get an error message anymore, but the VI got stuck somewhere else. Changing these VIs to accept real time stamps looks quite time consuming, so I think it is easier to change your waveforms to start at 0.
Andreas Jost
04-11-2016 06:52 AM
Thanks for the response. I've achieved the desired outcome using masking, as demonstrated in the Mask and Limit Testing of XY Graph example, which actually worked very well.
05-13-2020 03:46 AM
Hi DG76,
I have a same problem like you. I have DAQmx task - time window 100ms (1000 samples) and like you, when using t0 I get an error -20337.
Please, how did you solve this problem?
Thank you
Best regards
Real1ty
