02-19-2014 03:02 AM
hi! I am working on acquiring signal using labview. I acquire sound signal using a commercial microphone attached to my computer soundcard then using labview, i can view the signal, the frequency and save the data.
However, I need to convert this signal to sound file so i can hear it again. I did not record while i perform the test thus i rely on the data i saved (*.lvm form).
At my capacity to write programs ( Ialways use express), can someone help me?
I attached is an example of the saved signal i converted to txt file
02-19-2014 03:56 AM
Something like this:
/Y
02-26-2014 07:36 AM
This is so helpful and it worked with what I need.
Thank you so much.
An labview user here and just doing what is being asked even if I dont know if it works.
Thanks again.
