something similar to browse path control, but not quite
Hi all,
in my VI there is a 2D listbox. When I click on a line, in a subpanel a VI is loaded and data from listbox is written into controls in this subpanel. The VI in the subpanel then is finished.
A "browse path" control in the subpanel can be pressed, a new window is opened and I can choose a path, even though the subpanel VI is not running.
Is there an option to have a custom control, where I can open e.g. a new VI when a button is pressed? XControls don't seem to work or I am too stupid.
Thx in advance
(2,254 Views)
Hi Tesla,
customize a boolean button to show the same image as the browse button of the path control. Then you can call your own subVI when that button is pressed…
(2,247 Views)
Thank you for your fast answer.
Unfortunately, the VI in the subpanel isn't running anymore and so doesn't react to button press.
(2,243 Views)
Then you should not exit the subVI…
(2,240 Views)
