some unknown features
Hi everyone
I have some problem in the pictures, I do not know how to create the array . I show in the picture in the attachment.
Message 1 of 9
(2,851 Views)
The Search 1D Array (in the left diagram) is in the Array palette.
For the array constant, just drop down an empty array constant and then put a numeric in it.  Set the data type of the numeric to be a complex single.
The bottom right is the conditional terminal for the loop.  They default to be stop when true.  This one is configured to be continue while true.  You can just click on it with the finger pointer to switch it.
GCentral
Message 2 of 9
(2,844 Views)
in array constant, I will drag it down but it is not increasing the number of row?
is that for loop you mean?
Message 3 of 9
(2,840 Views)
Did you put a data type in the array yet?
The loop on the right is a while loop.
GCentral
Message 4 of 9
(2,834 Views)
as you can see in the picture, I can not add anything to the array or increase the size.
how should I do that?
Message 5 of 9
(2,824 Views)
Hi uni-pixel,
as has been said before: move a numeric constant inside the array constant. Then change it's type to Complex…
This is pretty basic LabVIEW stuff. Have you gone through all those FREE tutorials?
Message 6 of 9
(2,818 Views)
As I told you before, put a numeric constant inside of the empty array constant.
This is really basic things.  You should look into some of the free tutorials.
3 Hour Introduction
6 Hour Introduction
LabVEW Basics
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
Learning NI
Getting Started with NI Products
GCentral
Message 7 of 9
(2,812 Views)
sorry for asking simple things.
anyway, I did as you said but the pictures in the pannel are different.
can you explain how can i see the table in the block diagram?
Message 8 of 9
(2,787 Views)
Accepted by topic author uni-pixel
Right-click on the terminal and choose Change To Constant.
You could have created the array on the block diagram if you would have followed my directions earlier.
GCentral
Message 9 of 9
(2,774 Views)
