simulation two-mass system run on a fpga
I´m new to LabView and I need it for my bachelorthesis.
I have constructed a two-mass system of a machine tool with control design and simulation module to see the deformation in real time in result of the measured machining force.
Now I want to compile my system for the use on a fpga. The system must be discrete and with fxp-data type, but how can I convert the system and compile for my fpga cRio-9082?
Do any one know how to solve my problem?
Yanik
(2,488 Views)
Accepted by topic author Yanik25
well, you CAN use single precision floating point on FPGA. The cRIO 9082 also has a big FPGA. So you might just try doing your FPGA code using single precision float and see how much resources it uses-- from the apparent size of your program I think you can do it. Try it. The only thing that gives me pause is those gains on the order of 10E^7 , I wonder if you start losing precision there multiplying small by big numbers. Maybe think about scaling things different if it's a problem.
So gain is just a multiplication, you have that in FPGA. For doing the integrals you may have to "roll your own" using the old feedback node accumulator technique. basically you store the running integral in a feedback node (or shift register), each iter add the current value scaled by timestep. You could also use the discrete normalized integrator in FPGA-- scaling the input appropriately to a -1 to 1 range.
(2,428 Views)
oh yeah and use the FPGA simulation mode if you don't know about that. You will have to create a new VI under an fpga target and basically re-write that simulation code
(2,424 Views)
thanks for your answer.
Now it runs on my fpga.
(2,411 Views)
