11-03-2014 10:07 AM
OH..sorry...the pics cause your misunderstanding...
Pic of 2013 just a previous versions install screen form(http://digital.ni.com/public.nsf/allkb/E37B8A669CF7FD2E86257A5B006C6600)
Pic of 2014 is my installation process..........
I want know why the install process different between 2013 & 2014...
I want install 2014 Model Generation...How find it??
I download form ( http://www.ni.com/gate/gb/GB_EVALVERISTAND/US ) ,it's a full develop version..
Thanks a lot
11-03-2014 10:27 AM
Oh, thanks for clarifying that
I downloaded the 2014 Evaluation installer on my machine and found that you have to choose this option on the main page:
In order for the installation process to show you this page:
Otherwise it just chooses the standard features and doesn't let you include the Model Framework!
11-03-2014 10:33 AM
11-04-2014 12:37 AM
Hi...thanks your explanation..
I already install success,in matlab I try build a .so
It response an error...
I had install C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition 2013 that provide by NI
( http://www.ni.com/download/labview-real-time-module-2013/4286/en/ )
Error Message:
(C:\Users\LAN\Desktop\test\2014 labview matlab test\LabView_RT_DCBus_3_niVeriStand_Linux_ARM_32_rtw>C:\VeriStand\2014\ModelInterface\tmw\toolchain\Linux_ARM_32_GNU_Setup.bat && cs-make -f LabView_RT_DCBus_3.mk GENERATE_REPORT=0 NIDEBUG=0 NIOPT="Default" OPTS=""
Error locating the NI Linux Real-Time 2014 toolchain. Confirm the C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition 2014 was properly installed.
### Real-Time Workshop build procedure for model: 'LabView_RT_DCBus_3' aborted due to an error.)
NI Linux Real-Time, Eclipse Edition "2014"====>>is the issue point ??
11-04-2014 08:23 AM
11-04-2014 08:24 AM
11-04-2014 09:52 AM
I use cRIO 9068,
I builded a simple .so file using (C++ Development Tools for NI Linux Real-Time, Eclipse Edition 2013) and depolyed it to 9068 success!!
But the file is easy .c & .h ....and I manual generate the .so by Eclipse Edition...
I want use more complex file that like mdl converts..
I see the labview help (MIT can convert a mdl to .so file)
I think.. If solve the matlab compiler link Linux,maybe it would be ok!!
Really thanks for your reply.....!!!!
11-04-2014 09:57 AM
I will download the Eclipse Edition 2014 ,and try aganin!!
Thanks a lot!!!
11-04-2014 08:06 PM
Hi...I already generate .so !!Thanks a lot!!
It possible be used like dll in SIT??
I want call .so like dll,must import the .so but I don't have .h file(because generated by matlab & eclipse).
I reference the paper ( http://www.ni.com/white-paper/2818/en/ )
11-05-2014 07:19 AM
