11-02-2014 04:27 AM
Hi all..
I installed LV2014 & Model Interface toolkit..but I can't find the SIT function in Tool Menu,
Where can I install SIT??
thanks!!!
Solved! Go to Solution.
11-02-2014 07:36 AM
11-03-2014 04:03 AM
Hi Sir...
I need convert .mdl to Linux .so,I installered Veristand but can't find "NI VeriStand 2014 Model Framework".
I re-installer again,I didn't find NI VeriStand 2014 Model Framework as the feature to install.
download path
http://www.ni.com/gate/gb/GB_EVALVERISTAND/US
Where can I find "VeriStand 2014 Model Framework" install??
thanks
11-03-2014 07:47 AM
11-03-2014 08:06 AM
Thanks your reply....
I can't find NI VeriStand Linux_ARM 32.tlc that like below path description
http://zone.ni.com/reference/en-XX/help/374160B-01/vsmithelp/mit_convert_model_to_dll/
If I install success ,the License manager should have a Generation model toolkit,but I didn't see it!
In Matlab I had setting path..
11-03-2014 08:16 AM
Help show the needed install feature,but 2014 installer didn't find...
11-03-2014 08:38 AM
11-03-2014 08:49 AM
I'm using veristand 2014!!
In fact I just want using MIT to convert MDL to (.so)...
11-03-2014 08:59 AM
11-03-2014 09:28 AM
Ok so this is confusing.
Here's your screenshot, with some more boxes highlighting that you're actually installing the 2013 version:
I'm looking into why the "VeriStand 2014" Evaluation version includes 2013 SP1...
