simulating crio project on development computer
I am building realtime application to stream data from FPGA to RT over DMA FIFA and then perhaps using network shared variable for transferring to windows.
I am really surprised to see that I cant simulate the RT vi by executing vi on development computer. The previous application I build did not require synchronized communication so I used front panel communication and built the whole application on development computer before compiling. I wonder if it is to do with DMA FIFOs? I even pulled up the RT vi under windows computer but to no avail? Can we use development computer for RT VI debugging?
Kind Regards
(1,959 Views)
Can you please attach the code so I will be able to see it and understand better?
(1,896 Views)
