simulate signal for hardware to acquire
I am using ni-scope to acquire signal and perform signal processing. Is there a way to simulate a white noise and feed the noise to ni-scope, for it to acquire. I only use this to trouble shoot my code. Eventually, i will have the real signal connect to ni-scope.
Thank you!
(2,189 Views)
Use a analog out channel for passing the noise to the Scope. There are couple of vi built in for generating different types of noise
Regards
Guru (CLA)
(2,172 Views)
Thank you Guru!
I am not sure where is the Analog out channel.
(2,167 Views)
What Guru meant to say, I believe, is that you need something to physically generate a signal such as an NI DAQ board.
(2,140 Views)
