07-07-2014 02:39 AM
Hi Dennis_Knutson, I have look at the non-regeneration mode, my main problem is generating the 21 frequencies and amplitude values
continously as I explaine in my previous post. the sample rate is a default value when I want to run always change it.
07-08-2014 03:38 AM
Hello Juz,
Did you have a look at this example ("Voltage (non-regeneration) - Continuous Output.vi") in the Example Finder?
This seems to be able to do what you want to do (and more).
The only difference I see (compared to your explanation) is that it will try to iterate through your array of different sinewaces continuously (0,1,2,3,4,...,19,20,0,1,2,3,4,...,19,20,1,...) instead of only doing this once.
However, what you mean with the sentence "the sample rate is a default value when I want to run always change it" is not completely clear to me.
Either I am misreading this at my side or some words are missing. (both options have equal chances.. )
03-19-2015 10:02 AM
I would like to create vi to generate sine wave with floating offset and to collect data with the same clock and then, I process the data. Does anybody has an example of similar code ? I have everything working besides floating offset - and this is completely useless for me. So basically I need an example of data generation with floating offset - of course without using daq Assist (this is nice demo but it cannot be used in quite complex vi).
BR,
Jan
03-19-2015 10:38 AM
03-22-2015 10:59 AM
Right but the problem is different .... how to refresh output with new data - and some piece of code would be very helpfull .
03-22-2015 11:49 AM
