09-14-2010 06:50 PM
Hi
Attached is a view of a FP. I have an indicator (circled) that I would like to remove the shadow lines from, so that the numbers have no outline whatsoever (if doable).
The file is png format, so I hope I'm not going to get somebodies ire up....if I do.....my apologies.
Ray
09-14-2010 07:34 PM
Ray,
PNG is the preferred format for image files. So, thank you.
The easiest way to get a control or indicator to have invisible borders is to use the Classic controls. They do not have the shading effects and can readily be colored Transparent.
Lynn
09-14-2010 07:46 PM
Thanks Lynn
That'll do it
Ray
