settling time, rise time and steady state error
to find find the settling time, rise time and steady state error in simulation mode for the 2nd order system
(6,497 Views)
Is there a question in there?  We have no clue what you are doing.  You gave us absolutely no information on the context.
What is your problem?  What have you tried to do so far to fix it?
GCentral
(6,496 Views)
Suppose If i choose a Transefer function arbitrary and i want to find out the above mentioned parameter ,then how to do it..
(6,488 Views)
We do have this features implemented in the "LabVIEW Control Design and Simulation Module". The functions that that does this measurement is called "Control Design and Simulation >> Control Design >> Time Response >> CD Parametric Time Response". Here is the location of a complete example on that area:
<LabVIEW folder >\examples\Control and Simulation\Control Design\Classical Control Design\CDEx PID with Constraints.vi
Barp - Control, Simulation, RTT and HIL - National Instruments
(6,462 Views)
Can you please upload this vi as i am unable to locate the same in the examples folder....
(6,452 Views)
Again, this is part of the "LabVIEW Control Design and Simulation Module". This is an additional Module that you need to purchase and install:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/209850
Now, if you are an 'academic' user, it is very possible you have access to it through your university. I would try to contact your system administrator to verify its disponibility.
(6,447 Views)
