12-06-2012 10:50 AM
I wan to set the location of the x axis title to the bottom of the graph. It is currently on the top. I have been able to set all parameters except the x axis title location, Does anyone know how to do this? I've attached the graph and the code that I have used to format the x axis.
12-09-2012 11:20 PM
You can check this link for information:
http://zone.ni.com/reference/en-XX/help/372120A-01/lvoffice/excel_set_graph_font/
12-10-2012 02:44 PM
I already us this VI but it does not allow you to set X Axis location.
12-11-2012 11:50 AM
Hi Jasson
I have opened an example from the example finder and I was able to get the x axis label in the bottom of the graph.
Here is the example with some minor changes.
Regards
12-11-2012 11:57 AM
Which example was it or can you send me the VI?
12-11-2012 04:25 PM
The x-axis title is on top of the graph because you reversed the plot order of the y-axis. A workaround is to get a reference to the Axis Title object and then use the "top" property to offset the axis title from the top of the graph. Since your graph is fairly large you can start with a value of 500 to see where this puts the axis title.
Ben64
