02-25-2015 01:53 PM
I am trying to create an image and then save that to a file to be printed later. I notice that the picture functions seem to default to a 96 DPI image. Is there some way to increase that? I need to add some pretty small text to the picture and it is turning out eligible.
Solved! Go to Solution.
02-25-2015 10:27 PM
02-25-2015 11:05 PM
Tackle eligible? Or is it a Patriots stunt where you declare a running back ineligible?
02-26-2015 09:54 AM
If you save to BMP, you can specify pixel per inch in horizontal & verticle.
You have to modify the Write BMP File.vi a little bit, so that you can pass the header in, and not get overwrited.
02-27-2015 06:43 AM
I had just figured this out actually. This works great. Not sure why it doesn't come like this.
08-12-2019 07:36 AM
Could you please provide the solution?
