06-04-2014 02:52 AM
Hi..
I want to inteface GSM(with labVIEW) and PLC, My PLC will work in serial port only.
In my PC I have 3 serial ports. before installing the DSC module in my sytem, I can configure the all serial ports..but, when I finished instllation of DSC module, 2 ports does not working among those 3 serial ports. Before instllation,I can work with PLC and I can use other ports. After installations,I cant configure the those serial ports...Herewith I attached the error with this..... Please Help me soon.....
Solved! Go to Solution.
06-04-2014 02:55 AM
06-04-2014 03:08 AM
But I am not connecting with any modules such as GSM or PLC, the error was created even without connections of modules...
06-04-2014 03:13 AM
06-04-2014 03:21 AM
I tried it..and also,I am connecting a single operation in the fault error port. But same error..
06-04-2014 04:37 AM
The Solution is, no need to install the VISA device drivers seperately. We have to install the DSC module alone.
