06-18-2015 09:22 AM - edited 06-18-2015 09:25 AM
Please see the VI attached. This is the sender's side labview program
My task is to communicate various cases of event structure to a subsystem ( like laser) using serial communication and when it receives data, it send a acknowlegement in form of another hexadecimal code to 1st PC.
So for laser standby I need a code which is different from emission On or emission off...
My problem is how do i make the 2nd subsytems labview program.
Since i have to control only through 1st PC, I cannot include event structure in 2nd PC's program because in that case we need to manually change value in front panel of the program.
If i use state machine, will I be able to communicate between two different LabVIEW programs.
Please help. Thanks
06-18-2015 09:57 AM
Is this related to this thread: http://forums.ni.com/t5/LabVIEW/event-structure-Plese-help/m-p/3152399
