12-05-2008 05:13 AM
12-05-2008 05:52 AM
Hi mazhar.ali,
afaik you can send normal tcp messages over LAN so it should also be possible to send emails.
Mike
12-05-2008 06:05 AM
thanx
i hav to only use cRIO
12-05-2008 06:50 AM
Hi mazhar.ali,
what do you mean? Is your cRIO connected to the LAN? There are some third party modules for gsm.
Mike
12-05-2008 07:53 AM
12-05-2008 07:57 AM
Hi mazhar.ali,
ok, then i see no problem in sending emails with it.
Mike
12-05-2008 08:01 AM
sorry first my cRIO is connected via cross cable to my system
now i hav connctd to router via straight cable now i am not accessing my cRIO is there any settings to be changed
12-05-2008 08:11 AM
Hi mazhar.ali,
did you change the ip adress of the cRIO? It shoult be something like yours. I think the default adress is 0.0.0.0 and this could be a problem for your router.
Mike
12-05-2008 08:28 AM
12-08-2008 01:39 PM
Hi Mazhar,
Please look at this discussion forum for more information on using smtp with your cRIO. At this point, as I understand, you are connected using a router on the same subnet. As mikes81 has pointed out you do have to configure the IP settings accordingly.If you set MAX to obtain IP settiings automatically it should populate all the fields by itself. Hope this helps!
Ipshita C.
