03-06-2013 01:16 PM
Hi, i have this vi and i need to send a signal each time i get an output from an indicator. For example, if the cluster indicator shows "c" then a signal is sent to a port, if it shows "b" another signal is sent to a different port. I need to control relays with each signal and i have a total of 3 signals that need to be sent depending on the output a b and c. can someone help me with this
03-06-2013 01:18 PM
by the way i am new to labview and here is the vi
03-06-2013 02:50 PM - edited 03-06-2013 02:53 PM
03-06-2013 10:32 PM
thank you so much, i'll give it a try and let you know
03-06-2013 11:00 PM
03-09-2013 11:17 AM
so sorry, this is the vi
03-09-2013 11:19 AM
what is the difference between those two? i only need a way to send a signal depending on the result of the search function in my VI.
03-09-2013 11:22 AM
and btw i am using a macbook with only 2 usb port, if it helps
03-09-2013 11:24 AM
hi can anyone convert the vi parallel Exp to version 11.0 please
03-11-2013 01:02 PM
You can always post the vi to our Version Conversion forum to see if someone can convert it for you there.
http://forums.ni.com/t5/Version-Conversion/bd-p/VersionConversion
