semi transparent drawing over the picture
Hello every one
I am drawing the arrow image over the picture , so after drawing the arrow over the picture how to make it semi transparent so that background picture also should appear .
 Please see the attached vi
Message 1 of 10
(3,728 Views)
One option to consider is to place a transparent window on top of your existing picture.
Then draw on the transparent window.
steve
Help the forum when you get help. Click the "Solution?" icon on the reply that answers your
question. Give "Kudos" to replies that help.
Message 2 of 10
(3,721 Views)
Thank you stevem181
Can you explain in detail please with example .
My question is when i draw the arrow symbol over the picture , along with arrow background pic also should appear
Message 3 of 10
(3,712 Views)
@Nagaa wrote:
Thank you @stevem181
Watch this video developed from the good guys in the user interface user group. http://www.youtube.com/watch?v=gjYfqhlv2hQ
Message 4 of 10
(3,707 Views)
Thank you Strokes
I think you have'nt seen my vi in arrow.1zip file. Please see it
I want semi transparent drawing over the 2d picture at run time . Not when programming
Message 5 of 10
(3,687 Views)
@Nagaa wrote:
Thank you Strokes
Any chance you might have a go at attempting the solution yourself..?
If you make the 2d picture and transparent drawing into a custom control, you can use the visible property node to make it visible and invisible during runtime.
Strokes
Message 6 of 10
(3,684 Views)
Thank you Strokes
See the below pic i need this kind of output, transparent  drawing over the 2picture
Message 7 of 10
(3,679 Views)
@Nagaa wrote:
Thank you Strokes
Yes I understand what you're trying to do...
I don't understand what's stopping you from doing it yourself...
This will be my last post on the thread until you make some effort yourself
Message 8 of 10
(3,676 Views)
ok strokes
Previously also i tried with function Draw grayed out rectangle.vi
This function is supporting only for the shape rectangle . I want this kind of same function for irregular shapes also .
Message 9 of 10
(3,674 Views)
Generally, I would like to use image annotating control to draw images on pictures. You can add different types of annotation, such as primitive shapes, text, freehand, sticky notes, redactions, images, hot spots, callouts, rubber stamps, and ink.
Message 10 of 10
(3,431 Views)
