03-03-2005 11:36 AM
03-04-2005 10:01 AM
For starters, I suggest that you use the DAQ Assistant. It is the easiest way to control any DAQ cards using LabVIEW.
@KevinBolger wrote:
I have baught the NI USB-6008, I need labview to take each pin on this DAQ, match it too a boolean round LED, and turn the leds on & off as the signal into the DAQ changes.
You can create a customized leds. First, create a round led. Select it. Then go to Edit >> Customize Controls. Then viola, edit the led as you want it to be.
@KevinBolger wrote:
Is it possible to change the shape of the round leds? I need to use a filter arrow on the lights as well as the round ones, I've tried importing pictures but I loose all the nice texturing labview provides.
There is this additional toolkit called "Application Builder" which will allow you to build your vi's as executable files. Unfortunately, I think it is not available on Student Edition of LabVIEW. It is available, though, on the Professional Edition.
@KevinBolger wrote:
Finally once all this was done, if its all possible, does LabVIEW have the capability to generate an stand alone exe like publishing from solidworks or Flash MX to let this sim work in sand alone form?
I am very happy to help. If you have further questions, please don't hesitate to ask. :D:D:D
@KevinBolger wrote:
I know I have a lot of questions but I'm finding it extreamly hard to research all areas of the project with such a short timeframe, any help or suggestions with any of the questions would be such a great help.
Kevo
03-07-2005 04:50 AM
03-07-2005 10:15 AM
03-08-2005 11:04 AM
