09-06-2016 06:46 PM
Using scripting, I can create typedefs and save them. I can create a control, open the typedefs and insert them into a cluster in the new control. But they are just clusters in the cluster and lose the connection to the typedef. I need to keep them as typedefs. I can do it manually by creating the cluster and dragging the typedefs in from a project, but can't get scripting to do it. Any brilliant scripters there?
Solved! Go to Solution.
09-07-2016 09:13 AM
This works for me:
How were you doing it?
09-07-2016 09:24 AM
Great start, thanks. But now I want to add several more typedefs into the same cluster. Here, the NewViObject won't work, so I was using the Move method for the typedef cluster, with the owner being the main cluster. This works but inserts them as clusters, not typedefs.
I think I can make it work with the Move, then Replace method - still working the flow. Fortunately this is in a system setup procedure and not where performance is an issue.
09-07-2016 09:43 AM
(Hate to reply to myself) but that worked. Akward, but works.
Using LV Scripting:
-Create Cluster
-Create Typedefs
-Cluster->Move typedef into cluster (set owner as cluster)
-Get refnum (Open VI Object Reference) to cluster formerly known as a typedef
-Cluster->Replace with path to typedef
I now have a cluster full of typedefs.
If there's a better way, please let me know.
09-07-2016 10:56 AM
... and I would suggest you mark your (previous) response as the "Solution", just in case someone else has the same (or related) issue. Congratulations on your persistence and willingness to "experiment".
09-07-2016 12:21 PM
I don't know why you think that "NewVi Object" won't work; it works just fine:
09-07-2016 12:24 PM
I suspect that the reason you're not getting typedefs is that you are moving/copying a control from the FP of a typedef (which is not typdef'd) rather than moving/copying a control that is an instance of a typedef.
09-07-2016 01:11 PM
Pretty obvious why I didn't think it would work - cause I didn't think! Doh!
I Assumed it would create an additional cluster each time, and didn't test it.
Thanks for correcting me
