02-01-2006 09:28 AM
02-01-2006 09:44 AM
02-02-2006 05:37 AM
02-02-2006 06:10 AM - edited 02-02-2006 06:10 AM
Hi cdwyer,
In your second example's block diagram, you need to have the save button terminal and the associated case structure within your main loop, otherwise the button/case structure is only read/executed the one time.
An additional tip: When saving "computer graphics", like LabVIEW panels or diagrams, it's nearly always better to save them using the PNG format. PNG format is both compressed (small file sizes) and yet also "lossless compression" (no image degradation) - also it's usually preferable to use true colour (24 bit colour depth).
JPEG file type is a "lossy" type of compression that is designed for photographics - it will cause blurring and colour distortions when used with computer graphics.
Mark.
P.S. Worth a few star ratings?
Message Edited by Mark H on 02-02-2006 12:11 PM
02-02-2006 07:19 AM
