save waveform signal to .wav format
I am having difficulties saving a simple Sine wave to .wav format.  Does anyone have experience with this?   I just want to create a sine wave using simulate signal at a specific frequency and amplitude and save it as a .wav.  I tried using the Sound File Write vi and that doesn't seem to work.
Thank-you for any help.
Message 1 of 11
(5,902 Views)
Check out this example here.
The file download is messed up I think, but if you manually change the filetype to ".vi" it will open.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 2 of 11
(5,889 Views)
I am not sure why it is not working for you. Please post some code.
Spoiler
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 3 of 11
(5,876 Views)
Here is my attempt at save the sine wave file as a wav file.
Message 4 of 11
(5,867 Views)
  • Create a filepath for the file that you're creating. You haven't set any path.
  • Use the Open and Close subVIs from the same palette as the Write.
  • Make sure the file type is ".wav"
Cheers
Message 5 of 11
(5,858 Views)
Thank-you!  I made these changes (attached) and still get the same error.
Message 6 of 11
(5,835 Views)
This is the first time you've mentioned an error. What error?
Cheers
Message 7 of 11
(5,825 Views)
If you run it there is an error:
-4824
Message 8 of 11
(5,821 Views)
This isn't necessarily a warning, it's just letting you know that your data was out of range for a wav file, so it had to clip it.
Your waveform data must fit within the -1 to 1 range.
Cheers
Message 9 of 11
(5,811 Views)
Can you please look at the spoiler section in my first post
Message 10 of 11
(5,804 Views)
