NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
eliel
save value control
How can I save the value of a control and when I close the labview the values return to the control?
But the values changes some times.
How can i preserve this values when I open again the labview?
Thank You.
Trusted Enthusiast
TiTou
Re: save value control
I think you have to write the value into a file when your application shuts down and when it starts you have to load it from the same file.
Configuration file (INI) seems to be appropriate for that, the VIs are in a subpalette of the File palette.
If you need an example to start from, go to Help >> Find examples.. >> seach tab and look for "INI".
Hope this helps
________________________________________________________________
"Cambiar el mundo, amigo Sancho, que no es locura ni utopía. sino justicia."
Cervantes
Active Participant
P@Anand
There are two ways. As suggested by TiTou you can use the file to save the file (Mostly advised) else you can set default values to the controls which you can do by right click the control >> Data operation >> Make current value default or select the controls Edit>> Make Current alue Default. I would prefer writing to file :smileyhappy:
I don't believe in Hard work. I love my work :smileyhappy:
Knight of NI
This has been asked many times before. Did you search?
Community: Easy saving and loading of control values
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
