save value control
How can I save the value of a control and when I close the labview the values return to the control?
But the values changes some times.
How can i preserve this values when I open again the labview?
Thank You.
(2,984 Views)
I think you have to write the value into a file when your application shuts down and when it starts you have to load it from the same file.
Configuration file (INI) seems to be appropriate for that, the VIs are in a subpalette of the File palette.
If you need an example to start from, go to Help >> Find examples.. >> seach tab and look for "INI".
Hope this helps
Epictetus
Antoine Chalons
(2,981 Views)
There are two ways. As suggested by TiTou you can use the file to save the file (Mostly advised) else you can set default values to the controls which you can do by right click the control >> Data operation >> Make current value default or select the controls Edit>> Make Current alue Default. I would prefer writing to file 🙂
(2,971 Views)
This has been asked many times before. Did you search?
Community: Easy saving and loading of control values
(2,965 Views)
