08-27-2015 09:01 AM
I am running code where concatinated (as shown in the picture) string is saved as text file. When I run the VI it works perfect.
For example if Stock start (In dia) =0.5 and Infeed (mm/min) = 1
It will give : G01X0.5F1.000
But when build the Vi of same code, for same inputs concatinated string will be G01X0.0F0.000
I am unable to figureout the reason for this. I request your help to solve the bug.
Thank you
08-27-2015 09:04 AM
Please include a Snippet of your code, or attach your VIs, so that we can better assist you. We are here to help, but won't spend all day recreating code from scratch.
Since you're see a value of zero now instead of the other values, the problem doesn't lie with this section of code. Your data handling is going wrong somewhere, so you'll need to share more of your code for us to help.
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
