hello
i was trying to save the file in spreadsheet format. the data is feed from the table.
the file name is generated automatically from the time and date.
what i desire to do is to autosave the data. for example, the data of
the table in front panel generates continually from analysis of the
signal of sensor, but i need to save the file 10 row of data in one
file , (1st file contain 1-10th data,2nd file contains 11-20th data,
and so forth). it means file is saved while the vi is kept runing.?i
was trying to put the 'write file' in the while loop, but it pop up the
error saying that the file name is already exist.
now i can only save manually by clicking the boolean control. but i have to sort the file manually.
thanks
regards
