save Smith Chart to JPG
I am using the Smith Multi Plot VI in LabVIEW 6.1
There is an Get Image Invoke Node for the picture plot.
I am not sure if this is what I should be using or am I going down the wrong path.
I want to save that image to the hard drive as a JPG file.
(2,562 Views)
Accepted by topic author nyc_(is_out_of_here)
Use that property node and then the Write JPEG File.vi under the Graphics and Sound >> Graphics Format palette.
(2,553 Views)
Wow. That was easy. I thought I needed the Picture to Pixmap VI which isn't available in LabVIEW 6.1
Thanks.
(2,541 Views)
Is jpg format a hard specification?
Jpeg is not well suited for cartoonish images with sharp lines and hard edges, because you'll get significant compression artifacts. PNG is typically a better choice.
(2,524 Views)
Tried both and PNG is definitely better.
Thanks.
(2,510 Views)
