Hi dogface,
easy answer: because you wired a different datatype! Please note: you used a different local in case 2 and 3...
There are other things to mention:
Try to avoid stacked sequences (see case 0 in changed attachment)!
With error clusters in for loops you should use shift registers!
You can change the size of 'Index array' nodes!
Message Edited by GerdW on 03-19-2007 06:36 PM
