In one application I have a runtime menu which is dynamically changed. When a option is not available, the menu point is dimmed. Now I found out, that LabVIEW crashes every time when the runtime menu is opened while the change occurs in the program.
Is there a way to avoid this? Otherwise the whole option to change the runtime menu dynamically would be worthless..
Best regards
Dermot
