02-01-2016 01:36 PM
I'm running labview 2012 when I build a installer. I get an error. Some Installers you selected for this build are not available on this computer. The Installer is looking for NI Labview Run-Time Engine 2013
02-01-2016 01:40 PM
What have you selected under "additional installers"?
02-01-2016 01:40 PM
What happens if you de-select it and build the installer? Does your program install correctly?
02-01-2016 01:41 PM
I selected to 2012 Run-Time Engine to be installed.
02-01-2016 01:43 PM
Yes if I deselect 2012 Run-Time engine the build is fine. I never selected 2013 run-time engine to be installed. I'm running LV 2012
02-01-2016 03:47 PM
did you download and install run ti,e Separately that labview that you installed?!
02-01-2016 03:50 PM
No the run-time was part of the LabView 2012 development suite. I did build before and had no problem.
