03-08-2016 04:09 AM
I created exe file from my vi project. I wanted to run this exe on other computer that has labview run engine.When I run the exe file, i can not choose my instrument although i installed driver for my instrument. How can i resolve this problem?
Thanks..
Solved! Go to Solution.
03-08-2016 04:41 AM
Did you just copy over the executable or did you create an installer and include all of the necessary LabVIEW drivers that your software needs? Just installing the runtime engine will not work if your application uses other NI components e.g. DAQmx, NI-VISA etc. - that's why it is best to create an installer which includes these dependencies.
Typically you would need to install NI-VISA on the other computer.
03-08-2016 04:50 AM
As you say i install NIVISA and it works.
Thank you for reply.
