02-26-2013 11:02 PM
I created an executable file for my project. But when I tried to install the build in another system with no labview setup it shows that labview run time engine is missing. How to ovrcome this problem.
02-26-2013 11:15 PM
On your development PC, create an installer for your executable that includes the run-time engine.
Or download the run-time engine from ni.com and install that on the PC where you installed your executable.
02-26-2013 11:21 PM - edited 02-26-2013 11:21 PM
Have you include that package when installing EXE file. That is the example of LV 2011
02-26-2013 11:26 PM
Can you tell me the proper and necessary steps to make my program a stand alone application.
I just selectd the create exe from vi option in tools, selected the location and selected build.
What are all the steps to be filled.
02-27-2013 12:16 AM
Ya here it is.
Add the following components shown in attached file when creating exe file.
For project you may need this component also
Repeat the same procedure for NIReport.lib
May all the component you dont need but atleast take a reference
Let me know if you have any queries
02-27-2013 01:45 AM
To add to Ranjeets post, here are a couple of links from ni
http://zone.ni.com/reference/en-XX/help/371361J-01/lvhowto/build_installer/
http://zone.ni.com/reference/en-XX/help/371361J-01/lvconcepts/using_the_lv_run_time_eng/
02-27-2013 06:55 AM
Thank you for your useful links. I tried to follow the steps given but it shows the following window and does not complete building th exe.
02-27-2013 07:00 AM
Are you sure all the required component is added ?
02-27-2013 07:01 AM
when you are getting this error during building or somewhere else ?
02-27-2013 07:42 AM
That error is telling you that LabVIEW doesn't have some component needed in the build. I believe that error can be ignored, when you go to build the installer it will ask you for the locaiton of the component you are missing. Usually this is on a CD or download.
For example lets say in the Additional Installers you checked DSC but you don't have DSC installed. This error will pop up saying "Hey if you want me to include DSC in this installer I'm going to need you to give me DSC to include it". When you go to build it it will say "So where is that DSC you wanted me to include?" and you'll need to provide DSC either from a NI CD/DVD or from a download.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
