04-06-2017 04:16 PM
By default radio buttons show labels.
You can not change label of control in run-time, only caption or boolean text.
04-06-2017 04:22 PM
PS, no, radio buttons show boolean text. Just link to the button inside radio-button-cluster.
04-06-2017 04:22 PM
You can't change the Boolean text of the Booleans in the radio button?
04-06-2017 04:23 PM
That would solve my problem. How do you link to a button?
04-06-2017 04:41 PM
How do you create or link the property node to control? The same way.
Select control (button), right click it, Create -> property node.
OR
Put or copy Property node, Right click - "Link to", navigate to button inside radios
04-07-2017 03:24 AM - edited 04-07-2017 03:48 AM
the attached example shows how to change the boolean texts and the caption texts inside a radio button control. Obviously the labels are not changeable in runtime, just hide them.
Edit: this is a generic approach, which covers all booleans inside a radio buttons control. Use it if only the reference is available (e.g. access to a radio buttonc ctl. in another VI etc.), or if all texts must be altered at once.
Sorry, I haven't seen the other approch in Message 12 in the first place, it is more streight forward. So use it, if the control is placed in the same VI.
04-07-2017 11:56 AM
Can you reinitaliz
04-10-2017 06:37 AM
@labking33 wrote:
Can you reinitaliz
e default values of a radio button after program is complete? I tried to do this with an invoice node but received an error
Hi labking33,
I guess You mean an invoke node. Yes, it works - I've put an invoke node into the stop-button value-change event node, to try out.
Did You link the node to the radio button control or did You wire a reference to the invoke node? Maybe the reference became invalid before the invoke node has been executed.
I'm using LV2011, if that info may help for debugging.
