rt
Hello
I am new to real time acqusition and I am using cRIO 9024 with NI 9219 NI 9225 and NI 9215 for my data acqisition. I am acquiring the data in scan interface mode. I have modified the example of scan interface VI according to my requirement and it is working conditionally.
IN my program, when I run the VI first time it works fine, it writes the data to file which i can verify by seeing it but if I run it again it does not work and if I restart the RIO and run the VI, it again works. I am puzzled with this problem. I have included my VI here. If someone can give some inputs to sortout the issue, it would be great help.
Krishnab
(2,682 Views)
Accepted by topic author Krishnab
Your Stop variable should NOT be set to use a FIFO.  You want the last value at all times.  You likely still have a TRUE still in the FIFO which stops your loop.
You really should not use the Buffer shared variable.  Just use a normal Queue to send the data to your logging loop.  It will work A LOT better and greatly simplify the logging loop.
GCentral
(2,672 Views)
