08-10-2012 12:10 PM
I need to create custom bit sequence over rs-232 line. Is there a way to make it with USB-232 (SN/778472-01)?
Solved! Go to Solution.
08-10-2012 12:17 PM
What exactly do you mean by a "customer bit sequence"?
Is it something that will fit within normal serial parameters of start bits, stop bits, and data bits?
08-10-2012 12:37 PM
No start, stop, parity bits. I need to send only bits I specify.
08-10-2012 12:46 PM
Then no.
You need to use a DAQ card that has timed digital output. You would build your bit pattern has a digital waveform.
The only other question is what voltage levels you would need for a high bit vs. a low bit.
08-10-2012 12:47 PM
UART RS-232 requires a start bit and at least 1 stop bit. But this is usually handled by the transceivers. They are typically transparent to you or the instrument's processor.
