rounding numbers to the nearest integer in Excel
Hello everyone.
I use a write to spreadsheet file to export my array to excel (csv format), but it rounds the numbers to the nearest integer.
How can i solve that problem ?
My VI is uploadet
Thanks in advance
Oesen
Best regards
Oesen
Message 1 of 20
(2,897 Views)
Isn't it a problem with how your Excel cells are configured?
Message 2 of 20
(2,895 Views)
well.. It can possibly be that. Do you know how to configure the cells to get rid of integers ?
Best regards
Oesen
Message 3 of 20
(2,889 Views)
Look at the resulting file in a text editor (like notepad).  If the numbers look good there, then you know it is how Excel is formatting the cells.
GCentral
Message 4 of 20
(2,885 Views)
Hi Oesen,
I think the problem is the different decimal separator used in LabVIEW vs Excel...
Use a format string like "%.;%f" when creating the csv file!
Message 5 of 20
(2,879 Views)
I have exported the data to a .txt file, and it still shows integers
Best regards
Oesen
Message 6 of 20
(2,876 Views)
Exported how?  Export from Excel?  Or just open your CSV file with a text editor?
The export from Excel will just give you the same mess that you see in the cells.  Open the CSV file directly in a text editor.
GCentral
Message 7 of 20
(2,870 Views)
@GerdW wrote:
Hi Oesen,
GerdW,
If you look at the code, you will see that the format is "%.;%.2f".
GCentral
Message 8 of 20
(2,869 Views)
Hi crossrulz,
ahh I see...
@Osman:
Run your VI and attach the text file you created with that VI here...
Message 9 of 20
(2,865 Views)
Thanks for the answers
I opened my (Mappe 1.csv) file and saved it as a(Mappe 1.txt) file. After that, i changed my file path in the "write to spreadsheet file" box from (Mappe 1.csv) to (Mappe 1.txt), and tested it.
Best regards
Oesen
Message 10 of 20
(2,864 Views)
