09-11-2014 06:02 AM
Currently using the SCXI platform and Labview 2011 sp1. Until now its use was simply to record data. We have now purchased 2 more cards, one to control outputs and a strain gauge card. My question is if I want to do a sequence to control the output card, what would be the best way? For example I want output 0 to come on for 2 minutes, then output 4 for 3 minutes etc... I am somewhat familiar with PLC ladder logic so understand the function of a counter or timer but it appears that there is neither.
Any suggestions or help would be greatly appreciated. Thanks,
09-11-2014 06:37 AM
I would recommend a state machine. Have one state be an Idle state where you just use an Event Structure to look for a button press. Set the timeout to something like 100ms. That can then go to a state where you check the time that has elapsed. There is a nice Express VI called Time Elapsed.
