07-20-2005 04:31 AM
Hello, I am a starter with LabView and am trying to create a rising edge analysis. With the first rising edge of a Boolean Signal (an Input) a variable (and an Output) should be set and the second rising edge should reset this variable. It is like a RS Flip-flop with the second Set Signal as Reset.
By pressing an external pushbutton (my Input) my program should switch on/off my output to control an electrical system.
Maybe anyone can help me, Thank You!
Lars
07-20-2005 04:33 AM
07-20-2005 07:04 AM
07-20-2005 09:22 AM
Thanks for you answer, sounds very easy, but maybe I have not understand it or I am ….
In my german help file I cannot find information about state machine or about its translation and in my Test Vis the Boolean variable does not stay true when the control button (Input) is false again.
07-20-2005 12:12 PM
07-20-2005 12:48 PM
07-21-2005 03:07 AM
I got it! Thanks a lot to both of you. The VI with extra Set/Reset and Error is perfect and will help me to deal with some other problems. I will try to understand booth VI and they will help me to learn LabView.
Lars
