Hi TyWire,
The Repair approach was just to fix tbob's dir.mnu file. Whenever you corrupt a file in LabVIEW, you can always repair it. However, the original issue of tbob's (and what now also seems to be your issue) is that there is some problems with some VIs. Repairing LabVIEW doesn't touch any of your VIs.
I would check each of your VIs to see that they actually open and run correctly in LabVIEW 7.0. They should, but we wouldn't be posting on this thread if everything was working like it should :-).
If you don't find anything that sticks out as the culprit, I would recommend trying tbob's approach. Although tedious, it will get you back to ground zero. Uninstall LabVIEW and then Reinstall (not the same as Repairing). Then see if the same behavior occurs. If so, then post back saying so. If everything is working properly after reinstalling, make a note of the things that you change in the environment. That way if the situation comes up again, maybe you can pinpoint the action that caused it!
Hope this helps!
Travis H.
Travis H.
LabVIEW R&D
