Hello
I try to analyse the RGB values (max, min, mean, ect) of a 24bit bmp. i found a way to represent the pixelvalues as 24bit values in an array.
then i convertet the array into a dynamic signal. since the 24bit consists of 3 Bytes which represent the values of each rgb-channel i need to splitt this 24 bit into bytes. I found a VI vich changes the color format into rgb. the problem now is that the resulting values are single scalar which i really cant analyse with the signal analysing tool. i always get the same values for mx, min and mean, that means only one scalar value ist analysed.
How can i achive that the whole 2bit signal is splittet into byte-pieces in signal form?
can somebody help me?
Thank you very much!
Simon
Using Labview 7.1
