09-06-2005 03:04 AM
09-06-2005 07:49 AM
Hi TheGame,
You can use the Call Library Node function from within LV. Simply make sure that the CVI code function returns a value (example: int functioname (typedef value1, etc) ).
You can send the values to the function and it returns a value linked to an error code. For instance, 0 = no-error, -1 = bad error, etc. You can also return messages, such as +1 = function completed, etc..
Ooops, I'm getting carried away 😄
The Context Help provide adequate information on how to wire the Call Library Node. You can do a search on the function as well.
JLV
