reshape array
or if array sie is not the same .... (the last 3)...then delete those columns?
Message 1 of 18
(3,682 Views)
Message 2 of 18
(3,650 Views)
what is the upside down E function?
i cant find it.
Message 3 of 18
(3,635 Views)
look in the boolean palette. 😉 (...and it is not upside down, but mirrored)
Message 4 of 18
(3,630 Views)
Message 5 of 18
(3,618 Views)
i did the same block diagram as the image posted but i have the same results?
where is the true/false wire going to?
Message 6 of 18
(3,615 Views)
Message 7 of 18
(3,591 Views)
i didnt know where it was going so i just placed it next to the outter border of the for loop.
Message 8 of 18
(3,586 Views)
You need to right-click the orange tunnel to the right and select "tunnel mode: conditional". That conditional terminal is part of the orange tunnel.
(If you have an older LabVIEW version, you might not have that option).
Message 9 of 18
(3,580 Views)
Message 10 of 18
(3,571 Views)
