06-14-2005 08:31 PM
06-15-2005 01:07 AM
@Fat Controller wrote:
Hello World,
I'm using labView 7.1 with my first application, which is essentially a spectrum analyser and comparison to limits. now due to the parameters of the sampling 12000 samples/sec with 4096 point I have quite large chunks of data involved in rolling averages of 1 minute and rolling buffers that are an hour long. I'm pretty new to labview but I'm finding pretty easy to pick up except when it comes to optimisation and performance (I've been used to the microsoft approach until now) due to the fact that the instrument I'm building has to run in psuedo "real time".
I've been looking at replacing the shift registers with either queues or notifiers but I'm unsure if these techniques would result in improvements or not.
I'll attach a jpg of my main loop, I've only got the one but it is separated into three separate tasks but they are all governed by the data flow, DAQ then PROCESSING then REPORTING.
I've been told that by separating the loops and making them run in parallel LV will be able to compile it more efficeintly, but I'm unsure how to do that .
Cheers
Andrew
06-15-2005 03:36 AM
06-15-2005 05:44 PM
06-16-2005 01:32 AM
06-16-2005 06:33 AM
06-16-2005 06:10 PM
